NOISEY cold start ups with the pulleys, only to quiet down when warm.
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, NOISEY cold start ups with the pulleys, only to quiet down when warm. in Cadillac Engine Discussion; I have noticed my belt system is quiet noisey on cold start ups only to quiet when warmed up. Its ...
    lenny lincoln is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2007
    102
    I have noticed my belt system is quiet noisey on cold start ups only to quiet when warmed up. Its not a screeching noise of the belt but a bearning type noise. my water pump is not leaking, no difference with aircompressor turned on or off. Anybody experience anything similar? I cant imagine what would quite after warming up? Any ideas out there on what it could be or how to diagnosis the problem?
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    Re: NOISEY cold start ups with the pulleys, only to quiet down when warm.
    Had a similar issue, except that the noise did not go away at operating temperature.
    It was difficult to exactly determine the source by sound. I took the belt off and looked for pulley wobble when tugging on each pulley. During my 1st inspection, even the pulley tug did not produce the root cause. I continued to drive it for several weeks until the bearing loosened up enough to show during the pulley tug test.
    Btw...it turned out to be the water pump....oh, and no leaks either.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    57
    2,108
    Piston slap. mine does the same in the winter time. GM suggested a replacement kit (redisigned pistons and cylinder linings). I think it is not worth replacing.
