Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: 93 deville 4.9 noisey cold pulleys, quiet when warm. whats going out?
Old 10-22-07, 11:28 AM
Cadillac(s): Cadillac
View lenny lincoln's Photo Album
Casino Cash: $751
My 4.9 on cold mornings is very noisy only to come quiet after it warms up. Is not grinding noise. Can't tell coming from the air compressor, water pump, or belt tensioner. Anyone from experience that had similar symptomology could you please tell me whats about to go out. No water drips.
  #2 (permalink)
Old 12-03-07, 07:06 PM
Cadillac(s): 1994 sedan deville
View dadillac27's Photo Album
Casino Cash: $500
Re: 93 deville 4.9 noisey cold pulleys, quiet when warm. whats going out?
I have a 94 deville 4.9 and I had the same noise and it was my idler pulley. Hope this helps
  #3 (permalink)
Old 03-12-08, 02:37 PM
View maxxmicah's Photo Album
Casino Cash: $300
i have a 95 deville 4.9 and i had the smae noise and it was my idler pulley. too
  #4 (permalink)
Old 03-12-08, 06:06 PM
Chicano-Mexicano's Avatar
Cadillac(s): 1993 Eldorado Sports Coupe
View Chicano-Mexicano's Photo Album
Casino Cash: $4295
I have the same problem and that was my first though, glad to know that it's nothing major.
  #5 (permalink)
Old 03-12-08, 08:01 PM
Cadillac Owners Enthusiast
Cadillac(s): 93 Sedan Deville 4.9L
View behind-bars's Photo Album
Casino Cash: $14006
if its a squeal try replacing your power steering fluid. PS Fluid is often overlooked. You dont necessarily have to replace it all either, I just took the cap off and used a cheap turkey baster to suck all the fluid I could from the PS case and put it in a empty milk jug, I didnt get much out, but after adding new fluid till full the squeal stopped. I did it a few times over the course of a few months so that most of the old fluid was eventually removed. You can drain it all out at once if you pull a hose, but that will let air into the system which has to be bled out, A partial change keeps the bleeding to a minimum.
I would try this before a idler pulley since it is cheap and easy and should be done anyway, however if it doesnt work and you replace the pulley atleast you may prolong the life of the PS Pump
  #6 (permalink)
Old 03-12-08, 11:59 PM
Cadillac(s): 99 Base Deville
View 1stL's Photo Album
Casino Cash: $2130
My 95 Deville with the 4.9 was making a loud sound when I first got it (worse when I first started and drove it). I couldn’t tell what it was. Eventually it quit all together, but then I realized that another sound had developed. The new sound was a grinding sound and could really only be heard when the hood was up. The first noise was apparent with the hood open or closed. Turns out the alternator was going bad. My volts showed 13.7 to 14.1 on the dash the whole time so I didn’t think that it was the alternator. I put another alternator on and it’s fine now. When I removed the old unit you could spin the pulley and feel that it was bad. Maybe you could remove the belt and spin the pulleys on the alternator and power steering pump and see if anything turns up.
  #7 (permalink)
Old 03-13-08, 09:32 AM
Cadillac(s): 1993 Eldo 4.9 66K miles
View NickySantoro's Photo Album
Casino Cash: $4005
OP,
How old is the serpentine belt?
  #8 (permalink)
Old 03-13-08, 12:56 PM
92EldoTC's Avatar
Cadillac(s): Ex:'92 ETC 4.9 Current:'91 Sedan Deville 4.9
View 92EldoTC's Photo Album
Casino Cash: $1380
uh check the belt for cracks and change the idler pulley soon before it goes out and you lose control of steering and eat your serpentine belt up, been there done that, not fun!!
  #9 (permalink)
Old 03-27-08, 10:15 AM
Casino Cash: $751
It was the water pump. New idler and belt was replaced when i did the pump. All quite now
  #10 (permalink)
Old 03-28-08, 09:19 PM
92EldoTC's Avatar
Casino Cash: $1380
squeaky pulleys, whether it be water or power steering pump, alternator or idler, isolate the noise, replace and enjoy the quiet!
  #11 (permalink)
Old 01-07-09, 11:36 PM
Cadillac(s): 92 Deville
View McQueen95's Photo Album
Casino Cash: $300
Question Re: 93 deville 4.9 noisey cold pulleys, quiet when warm. whats going out?
This is great thread that I found while searching the forum. So... about "isolating the noise". I need some help with that. I think it's coming from one of the idler pulleys (93 Seville 4.9L). It's a relatively new sound and it's not too loud but it is very pronounced. It sounds like maybe bearings that have gone bad on an idler pulley or a power steering pulley. It's kind of a low sounding "grind" noise... very steady sound... not intermittent.
I'm 90% sure it's not coming from inside the engine. If I take the serpentine belt off completely, can I run the engine that way (at least for a couple of minutes) or do I risk creating a bigger problem? If the sound goes away, then I would at least know that it's something that is being driven by that belt. In case that doesn't help, I would appreciate hearing any suggestions for troubleshooting noises... inside or outside the engine.
I'm new to the forum and this is my first post...and obviously not a pro mechanic but I know enough to be dangerous and save myself a few bucks (most of the time ). Thanks to any who offer some advice.
-mq95
  #12 (permalink)
Old 01-08-09, 12:48 AM
Casino Cash: $14006
If you cant isolate the sound with the belt on and engine running then I would pull the belt off and spin the pulleys by hand. I imagine you could run the engine for a minute without the belt, but I would be a little hesitant too run it more then a minute or two. When my waterpump went It threw the belt and the car ran a bit before I killed the engine and I dont see any damage, After the belt fell off I spun the waterpump pulley by hand and you could hear the shot bearings and the pulley was loose so I knew it was bad.
If you think it is a PS pump then have someone stand outside with the hood up and engine running and turn the wheel back and forth and see if the sound varies.
Tags: , , , , , ,
cold, deville, noisey, pulleys, quiet, warm
