'88 DeVille EXTREME ISC problems
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, '88 DeVille EXTREME ISC problems in Cadillac Engine Discussion; Hey everyone. I'm not sure if you all read my post in the FWD forum that my '89 Fleetwood was ...
    SlxAlxx's Avatar
    SlxAlxx is offline Cadillac Owners Fanatic
    Feb 2007
    306
    Hey everyone. I'm not sure if you all read my post in the FWD forum that my '89 Fleetwood was destroyed last weekend. I'm going to buy an '88 Sedan DeVille as it's replacement with only one issue: the E30 code. My Fleetwood had the code intermittently and would idle high when first started and went to normal about two seconds later every time. This DeVille idles in the correct RPM range, but the idle is VERY rough and sporadic. The engine is jerks but accelerates beautifully. The E30 code comes up every time the car is started, but not always right after starting. What I was wondering is if there was any issue besides the ISC motor (i.e. spark plugs, etc.). The current owner has claimed that a lot of parts have been replaced on it and according to my thorough inspection, they have been. Any advice to this novice would be greatly appreciated!
    SlxAlxx's Avatar
    Feb 2007
    306
    Re: '88 DeVille EXTREME ISC problems
    I just heard from the current owner of the car that the ISC motor was replaced this year. Apparently, the technician that installed it did not adjust it. Is it true that I need a 12V power supply to be able to do such?
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    No, see my posts on the ISC issue (and also those by others). I personally think my adjustment method is easier.
    I also had an E30 code and traced it to a worn distributor drive gear. The slop in the gear was causing erratic idle timing, which the ISC was trying to overcome.
    SlxAlxx's Avatar
    Feb 2007
    306
    How did you repair that? (Just in case that may be my issue)
    Jun 2005
    Michigan
    668
    It's not too bad of a job. You have to pull the distributor (remove the hold down bolt and clamp), and pull straight up. Then, you remove the gear by punching out a small pin with a dull punch at the end of the distributor.
    When I removed the distributor, I took several pictures with my camera of the rotor position, then made sure that it lined up when I reinstalled it.
    If you have a timing light, jumped the 2 pins on the ALDL connector and check your timing. If the timing mark dances around a lot, this may be your problem.
  8. Remove Advertisements
