I Lost First Gear, Car barely moves with throttle!
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, I Lost First Gear, Car barely moves with throttle! in Cadillac Engine Discussion; OK well i am sittin in a line up for the ferry, everyone starts moving, then i fire up my ...
    caddeville's Avatar
    caddeville is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Deville / 1989 BMW 635csi
    Jan 2005
    British Columbia, CANADA
    26
    896
    OK well i am sittin in a line up for the ferry, everyone starts moving, then i fire up my caddy, put it in drive, step on the gas and the car clunked very harshly BOOM AFTER it smoothly engaged into drive, i'm going WTF!?, stepped on the gas, i feel a grinding, rpms are at 2000, and the car barely moves. Well i got off of tyhe ferry, put her in gear, now its engages a little rougher than usual, i stepped on the gas, rpms go up, car barely moves, then eventually starts going, As this whole time i am feeling a grinding. I hit second, then came out of second then went in second again. Once it hits second gear, its fine. But i mean off the line i can't go, especially up a hill. Luckily i have an extra tranny in my parts car, 1988 Fleetwood, tranny is which rebuilt.
    But what could have happened? The car has 102,000 MILES.
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    57
    517
    Re: I Lost First Gear, Car barely moves with throttle!
    I know the designs are quite different, but I had something similar happen on my 78 Eldo once... the 3rd gear planetary carrier 'broke' and basically locked it into 3rd gear.
    Drove it all the way where I was going, and parked close to the front door..... THEN later tried to back up and found that reverse was not working....
    Ended up lifting a drive wheel w/ a rolling jack so that the thing could be backed up enuf to turn away in drive.
    Definately sounds like something worthy of the 'spare'!
    Tommy Deville's Avatar
    Tommy Deville is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    Quote Originally Posted by caddeville View Post
    somthing very similar happned to my 89 coupe, it had a reuilt in it when I bought it, basically the diffrental exploded & wrecked the trans, the mechanic said it looked like a bomb went off inside the transmisson. wound up getting a junkyard trans & selling the car
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Remember, the trans in these cars is basically a THM125c with a 4th gear added on: it's not that strong. With abuse, it will fail. If you drive it normally, it will last a long time.
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    They can be rebuilt to be a lot stronger. There are aftermarket parts such as Transgo shift correction package that beefs up these trannies.
    You might try replacing your filter. Sometimes, the filter gets clogged with clutch sediments and there is not enough pressure to give any clutch holding power. But it is very likely your transmission is in need of a rebuilt. I rebuilt mine myself and it was $80 for the rebuild kit, $30 for the Transgo shift correction package and $80 for a rebuilt torque converter. It is not all that difficult.
    caddeville's Avatar
    Jan 2005
    26
    896
    Everything is done and working, i took the rebuilt tranny out of my 88 fleetwood and replaced mine in a day and a half. Everyhting is almost fine, i made another thread about the speedometer being off, if you guys can help me out there that would be spectacular! Thanks!
    And yes i abused the tranny quite a bit, but i am going to take it easier with the fresh tranny. teh car actually has alot more power. i alos chanegd the fluid and filter and the tranny was not overfilled.
  9. Remove Advertisements
