1985 4.1L Distibutor Drive Gear for oil pump
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, 1985 4.1L Distibutor Drive Gear for oil pump in Cadillac Engine Discussion; What's involved with changing the distributor drive gear? I've changed my oil pump,shaft and pickup screen and still get a ...
    whatever243444 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    4
    What's involved with changing the distributor drive gear? I've changed my oil pump,shaft and pickup screen and still get a low oil pressure light and no oil coming out of push rods. So i'm down to the drive gear i think. any other suggestions?
    Feb 2003
    california
    69
    6,627
    Re: 1985 4.1L Distibutor Drive Gear for oil pump
    Once the distributor is out of the engine, you drive out a small roll ping retaining the gear at the bottom of the distributor. Press on the new gear and drive in the roll pin. Should be very obvious wear on the old vs. the new gear.
