6.0L? say what?
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, 6.0L? say what? in Cadillac Engine Discussion; I was reading old threads and found a link to EDEN interchange site , which says that I can put ...
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    6.0L? say what?
    I was reading old threads and found a link to EDEN interchange site, which says that I can put a "8-368 (6.0L) 4BC (VIN "6")" or "8-368 (6.0L) EFI (VIN "9")" in my 85 DeVille. I'm guessing the first one is 4-barrel carb and the other is fuel injection.
    What I don't know is what engine are they talking about?
    I wish I hadn't looked, now I'm thinking about it!
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    Re: 6.0L? say what?
    link
    In 1980 the 425 was replaced with the L61, which was the same basic engine de-bored to 3.80 in (96.5 mm) for a total displacement of 368 in³ (6.0 L). The reduction in displacement was largely an effort to meet CAFE requirements for fuel economy. Fuel injection (which would be known to GM as throttle-body injection after 1985) was now standard except for Fleetwood Limousines and Commercial Chassis.
    Cadillac refers to the fuel injection system as digital fuel injection; this particular induction system was later adopted by other GM division except Oldsmobile V8s.
    Power output dropped to 145 hp (108.2 kW) @ 3600 rpm and torque to 270 ft·lbf (366 N·m) @ 2000 rpm. This engine was standard on all Cadillacs except the redesigned Seville, where it was optional.
    Only 20 more hp than the HT4100, but it would probably be a good basis to start with (especially the four-barrel). I don't think it was available in transverse mount though.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 6.0L? say what?
    Quote Originally Posted by ehall View Post
    It never was available in transverse mount. I think what the article meant was that you could put the 368 into a 1985 Brougham rear wheel drive car.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 6.0L? say what?
    Even a RWD HT-4100 won't fit in a sideways FWD application. They are 2 different engines. Bellhousing isn't even close. The FWD engines had less issues. You are looking at a description of engines used in RWD cars. The 1985 Fleetwood Brougham was still RWD and used a RWD version of the HT-4100. The Fleetwood limos used a 368 with TBI. "They" say these had the 8/6/4 stuff also. I have not run into one. 368 was not used in any factory FWD car.
    No way will a 368 bolt into a FWD Deville. BTW, a 425/472/500 will bolt in anywhere a 368 fits.
    Anyway it's not too important because you said that your HT-4100 was good for another 100,000 miles.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    Re: 6.0L? say what?
    The mechanic said I could get another 100k out of it, doesn't mean I'm going to keep it that long. It's got really weak compression in one of the cylinders and a couple of others are dragging, plus the HG won't last forever. I've pretty much decided that I'm going to replace it with another HT4100 (Jasper probly) so that it's almost stock. But then I see these other articles about Allante 4.5's and now this 6.0L and all my careful thinking is instantly mooted by sudden lust for power.
  8. Remove Advertisements
