85 Deville 4.1L Oil problems.
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, 85 Deville 4.1L Oil problems. in Cadillac Engine Discussion; I've just replaced my oil pump,shaft and pickup screen and my oil light still comes on and there is no ...
    whatever243444 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    4
    Question85 Deville 4.1L Oil problems.
    I've just replaced my oil pump,shaft and pickup screen and my oil light still comes on and there is no oil coming out of the push rods. What next?
    Feb 2003
    california
    69
    6,664
    Re: 85 Deville 4.1L Oil problems.
    Distributor drive gear.
    caddeville's Avatar
    caddeville is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Deville / 1989 BMW 635csi
    Jan 2005
    British Columbia, CANADA
    26
    896
    What does that mean?
    Feb 2003
    california
    69
    6,664
    It means the gear on the drive end of the distributor could be worn eccessively.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Did you prime the pump?
    Feb 2007
    4
    I primed the pump before i installed it.
    Feb 2005
    Southern NJ
    54
    2,096
    I'd look for a sheered off roll pin in the distributor then. I assumed you had done that before digging into the oil pan. My bad.
    Feb 2007
    4
    I have replaced the oil pump,drive shaft and pickup. I have pulled the distributor and the drive gear is fine. I filled the oil pan with enough oil to submerge the pump and primed the pump. I get oil flowing into and out of the oil cooler but i still don't have any oil pumping out of the pushrods. What could be left?
  11. Remove Advertisements
