4.1 Engine: Sensor Above #8 Spark Plug?
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, 4.1 Engine: Sensor Above #8 Spark Plug? in Cadillac Engine Discussion; I broke the terminal lug off the small sensor that is threaded into the engine above the spark plug for ...
    PeteC is offline Cadillac Owners Member
    Automobile(s): 1987 Eldorado
    Jul 2004
    Hampton, VA
    82
    I broke the terminal lug off the small sensor that is threaded into the engine above the spark plug for the #8 cylinder. The engine seems to run fine still.
    What is this sensor?
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Re: 4.1 Engine: Sensor Above #8 Spark Plug?
    It sounds like the engine metal temperature sensor. It illuminates the "stop engine temperature" idiot light when the head temperature goes above something like 250 deg. F.
    Peteski
    Murphyg's Avatar
    Murphyg is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 STS
    Oct 2003
    Ontario
    1,575
    I broke that in my 4.9.
    Was able to remove it and taped it together with aluminum tape. Worked quite well
