Torque converter lock up solenoid, Where?
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
HT4100 4.1, 4.5, 4.9 Discussion, Torque converter lock up solenoid, Where? in Cadillac Engine Discussion; My 87' caddy (FWD) downshifts hard from 3rd to second and bumps barely from second to first. Once very fully ...
    caddeville's Avatar
    caddeville is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Deville / 1989 BMW 635csi
    Jan 2005
    British Columbia, CANADA
    26
    896
    My 87' caddy (FWD) downshifts hard from 3rd to second and bumps barely from second to first. Once very fully warmed up, it goes away, but i can still barely feel it. I was told before it is the torque converter lock up solenoid, but i'm nto sure, if it is, where is it located and how hard is it to change? Tranny fluid up to level and smells like the day i put it in. Thank you.
    I fixed the car in mid august, this time the grill is gold center and gold license plate frame added. No one will ever know it was fixed no matter how hard they look.
    But please help me with the tranny, it's been doing this since end of winter, i've made thread before. Thanks again.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    Re: Torque converter lock up solenoid, Where?
    Any codes?
    Feb 2003
    california
    69
    6,680
    Sounds to me like the trans TV cable is disconnected or mis adjusted. The TC solenoid does not work below 35/40 MPH. The cable attaches to the bottom of the throttle lever and is pulled forward as the throttle is opened which determines up shift interval and smoothness of down shift. With it popped off the lever verify there is tension as you pull it out. Should spring back to rest. If not, its disconnected at the valve body. You need a shop manual to adjust it correctly or any trans shop can verify its ok.
    caddeville's Avatar
    Jan 2005
    26
    896
    ok, i've adjusted the kick down cable many times at the throttle lever, noting changes. You mean the valve body at the tranny? is this anything i could fix myself?
    Feb 2003
    california
    69
    6,680
    Did you verify spring tension on the cable. With it disconnected and pulled out does it spring back?
    caddeville's Avatar
    Jan 2005
    26
    896
    the cable does spring back, but how fast should it be? Should i be able to pull it out easily with my fingers once disconnected from throttle lever? It doesn't pull out easily, only once its connected to throttle lever.
    Feb 2003
    california
    69
    6,680
    Yes, it should spring back quickly. If not, then its binding on the black sheath over it. Remove the bolt holding the cable to the trans. Lift up on the cable assembly and gently disconnect the cable from the trans lever. Replace the TV cable assembly by reconnecting the cable at the trans then at the throttle body. Adjust according to the service manual. Another item to check is correct amount of vacuum to the modulator. If the vacuum source is plugged with carbon, the modulator will either get no signal or a very weak one. Follow the pipe from the modulator up to where it attaches to the throttle body. Use a small allen wrench and carb cleaner to make sure the vacuum port is clear at the throttle body. Lack of vacuum will cause harse downshifts.
    caddeville's Avatar
    Jan 2005
    26
    896
    ok thank you, yes i pulled he cable off of the trany. Everything is free. Where is the modulator located?
    Thank you for being so patient and taking the time to explain what to do, i really appreciate it.
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Carnut is bit off here. This transmission setup only uses TV cable. There is no modulator valve. TV cable does the job of both the downshift cable and the modulator valve. So, TV cable is the only adjustement to be made.
    Peteski
    caddeville's Avatar
    Jan 2005
    26
    896
    so the tranny shifts rough, i can't really do anythign about it, maybe i should change oil agian and throw in an additive or something
    Feb 2003
    california
    69
    6,680
    I believe this trans still used a modulator?? 440t trans. My 88 CDV as well as my 88 Allante both had modulators. Located below the forward cyl head close to the radiator. A metal line went from the throttle body to it. Small rubber hoses at each end connected it. Large grey or black canister. On my Allante, cleaning the vacuum port controlling it helped the harsh coasting to a stop, down shift.
    Dec 2003
    Northeast USA
    808
    OP didn't say which model (but he said FWD 87). My 85 Eldo with HT4100 doesn't have a modulator valve. I don't recall the model of my transmission. Its FSM states that the TV cable replaces both the downshift cable and the modulator valve. So, I figured that OP's car would be similar.
    Peteski
    caddeville's Avatar
    Jan 2005
    26
    896
    85, 86, 87, 88, and 89 fwd C-body caddie deville and fleetwoods have the same transmissions, either way i have a 1988 caddy fleetwood parts car with rebuilt tranny in it anyway. Has the 4.5 but has oil coolant coolant oil dealeo, either intake or head gaskets. has 104,000 MILES,
  16. #14
    Feb 2003
    california
    69
    6,680
    85's have a 325 series
  17. #15
    caddeville's Avatar
    Jan 2005
    26
    896
    oohh well didn't know that, they look the same, are the 85 devilel trannies worse in reliability than the later ones?
  18. Remove Advertisements
