85 Eldo HT 4100 ISC/TPS
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 85 Eldo HT 4100 ISC/TPS in Cadillac Engine Discussion; I have a couple questions. I have used the search function and found valuable info, but also found conflicting info. ...
    85moeldo is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac STS
    Jul 2007
    Smithville, MO
    17
    All post I have seen say to set gap for ISC to .030 inch but this link says to set at .060 inch - http://www.ht4100.com/Diags/HT4100ISC.pdf
    Is it different based on year/model?
    Also, instead of using voltmeter for TPS setting can you use the ECC diagnostic parameter .0.1 and set to 0?
    Has anyone done mods to air intake or exhaust to help it breath better?
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Re: 85 Eldo HT 4100 ISC/TPS
    It's 0.03" for 4.9 liter. I do not think you'll be way off if you set it 0.06" though.
    Feb 2003
    california
    69
    6,643
    The bottom line on the ISC is there is a gap between it and the throttle lever when at minimum idle. With the ISC fully retracted the engine will idle very low approx 450 to 500. If the lever and ISC touch, the switch within the ISC, it will continue to try to control idle speed. For more performance, you can install the larger throttle body from an 81 368 engine which has larger throttle blades. You must use the thick base gasket so the blades dont hit the intake manifold. Swap over your 2 injectors to it as well as your TPS. This gives you more air at a lesser throttle opening which gives the engine more torque around town. Yes, you can set parameters thru the on board display. Set the timing at 12 instead of 10.
    Jul 2007
    Smithville, MO
    17
    HUF & carnut - thanks for the replys.
    I must still have a vacuum leak, got a surging idle, and no way to set min air idle with that. I have replaced all hoses around intake, TB, and to canister, but still a rough and surging idle. I replaced orig TB with a rebuilt and may have over torqued bolts, not to spec just cranked em down, and tweaked base gasket.
    Carnut, thanks for info on 81 TB. May do that down the road. Right now I need to replace heater core, started leaking yesterday on way to work. Never ending saga!
  7. Remove Advertisements
