1985 Eldorado Engine Died! help!
Results 1 to 10 of 10
HT4100 4.1, 4.5, 4.9 Discussion, 1985 Eldorado Engine Died! help! in Cadillac Engine Discussion; Help! I have a 1985 Eldorado and the engine just died on me while I was driving. It was running ...
    mayorjesse is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    10
    Help! I have a 1985 Eldorado and the engine just died on me while I was driving. It was running rough prior to that - thought it needed tune up - been driving for past 2 days fine, drove it faster last night and right as I get to my apartment it just dies (before I parked - pushing this guy is heavy!). The starter seems to sound louder now, like a whine. When I went to try starting it up this morning it sounded like a screeching belt sound when it started up and then it died again and would start up.
    engine turns over but doesnt catch. Could timing belt have gone? If it went while car was driving, is that bad? If it is something else, let me know!
    Thanks!
    Jesse
    Aug 2007
    10
    Re: 1985 Eldorado Engine Died! help!
    I meant to say it would not start back up in that sentence there.
    It has the HT 4100 with a recent thermostat, waterpump and intake put on. the oil looks clean as new, same inside too. All warning lights seem to be functional.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Check to see if any of the fan belt driven accessories are siezed.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Good point by Ape Man. It could be that the timing chain has slipped. Do you hear a popping noise when trying to crank the car over? If so, then your timing chain may have slipped.
    Aug 2007
    10
    No popping sound that I can hear. Could be AC compressor? I know when I put on AC it was harder on engine - idled rough - I wasn't using AC but maybe the clutch seized or something like that?
    Jun 2005
    Michigan
    668
    Maybe, pop the hood and push on the A/C clutch with your finger. It should be loose--i.e. when you push it, it will move ever so slightly. Or you could just remove the A/C belt. That might be a good place to start..Just take off all your accessory drive belts and try to start the car.
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Quote Originally Posted by mayorjesse View Post
    Thanks!
    Jesse
    I am betting on an ignition module or coil. See if you get any spark at plug wires.
    Aug 2007
    10
    hey all! success!
    So I tested wires/coil - coil was shot and wires were cruddy. Replaced them and got spark back, started for like a minute then died again - thought it was back to the drawing board, but...realized I was on a steep hill and gas was low - tossed some fresh 91 in the tank and she was back up and running - a little better than before too, prob cause of fresh wires. Remember, these fuel tanks seem to pool away from fuel pump on big hills (had same prob with my 83 olds cutlass - would sometimes die on extended steep grades). I got a nice little fire show in the carb too (not really cute, but kind of exciting seeing a large flame shoot out of your carb).
    The car is still running rough though, not quite up to speed. Mileage seems to be bad too - averaging around 8-9 mpg in city. Spark plugs looked new - or at least the one I checked before I just put on new wires. Looks like car has new intake, water pump, thermostat, and i think heads (looks new inside under the oil filler cap on valve cover). When I put key in ignition, the gas pedal does this weird popping noise and fluctuates ever so slightly as it does, almost in sync with 6 warning chimes that also go off when I put key in and and turn to ACC before I start engine. Strange ghost there - is this normal or evident of something?
    Also, I think my starter is going but could use verification. When I go to start about 50% of time now it gives a high pitched sound like starter isn't catching. When it does catch and start, sound like I have a belt that's not too good. Sometimes it's all right, but still seems like a belt might be bad. Could a bad belt affect the starter?
    Thanks for help! Just got this car and it has a couple issues but I love it's style and am working out kinks - any help is well appreciated!
    Feb 2003
    california
    69
    6,680
    I think you have at least 2 issues. A damaged ring gear which would account for the sound from the starter. Pull the torque converter dust cover and inspect the large ring gear bolted to the t/converter for a damaged section of gears that mesh with the starter. Second: belt squeal noise is usually a loose smog pump belt which will cause a squeal when first started because at that time the alternator is recharging the battery putting more tension on the belts. The ratcheting of the idle control motor causing the gas pedal to move is either a misadjusted idle speed motor or a faulty idle speed motor. You need the factory service manual in order to properly adjust it or replace it.
    Aug 2007
    10
    cool i'll prob be able to check all this sunday or monday. Thanks!
  13. Remove Advertisements
