A 4.X Water Pump Story - Not for the Faint of Heart
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, A 4.X Water Pump Story - Not for the Faint of Heart in Cadillac Engine Discussion; Just finished the water pump on my '87 HT 4100. It was a bit more challenge than I envisioned. You ...
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    58
    1,296
    Just finished the water pump on my '87 HT 4100. It was a bit more challenge than I envisioned. You can read the whole bloody saga on my blog if you like:
    http://www.cadquest.blogspot.com/
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: A 4.X Water Pump Story - Not for the Faint of Heart
    Wow--
    There's always that one bolt, isn't there? Glad your car is working again.
    I say this while knocking on wood, but I'd be very surprised if there's much left to fail on your car, given that you've already replaced the alternator, water pump, A/C compressor, and EGR system components. Despite the occasional issue (I've replaced my alternator and EGR valve thus far), my 4.1L Cadillac has been uber-reliable. I also finally traced my hesitation problem to a plugged breather and sticky valves which I've half cured by spraying carb. cleaner on the valves while the engine is running. I still need to remove the back valve cover and perform this treatment. You may want to try something similar next time you have the valve covers off. I think a varnish built up on the valves/guides when the intake gaskets blew which was causing a few valves to stick open at higher RPMs.
    Best of luck with your 4.1 Cadillac.
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    Yeah, I had that same problem. When I replaced the torx bolt, I used a standard bolt screw with a short head; it still works fine on my '87 Seville.
