4.5 Cooling System Woes...
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, 4.5 Cooling System Woes... in Cadillac Engine Discussion; Hey guys, I have a question about my 89 Eldo... My car will run at 180 degrees all day on ...
    DrCheeto's Avatar
    DrCheeto is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac Coupe DeVille
    Jul 2007
    Kansas City,MO
    34
    3
    My car will run at 180 degrees all day on the highway... If i get OFF the highway, It slowly climbs, i've seen it go as high as 225... I know that it is really this high, i used a real temp gauge to verify the accuracy..
    I know 225 isn't technically "overheating", but it scares me. I just replaced the thermostat, radiator cap, flushed the system and it still does the same thing...
    Is this normal? Am I worrying myself? or is there something else I should check..
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    Re: 4.5 Cooling System Woes...
    Have you checked to see if the cooling fans are working? The module that controls them is a pretty common failure item on these years of Cads. Try turning on the A/C when the engine is warm - both fans should run.
    Also check trouble codes, be watching for an F41.
    DrCheeto's Avatar
    Jul 2007
    Kansas City,MO
    34
    3
    My fans work fine, I usually drive around with the a/c on anyway... Today i drove around and the highest i saw was 213...
    I know its not crazy hot, but it still worries me and i want to get to the bottom of this.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    It might be fine. When you get off the highway and stop by a lite in the summer time the temp. will go up really fast. The fans should strat at about 225 and bring it down to 212.
    DrCheeto's Avatar
    Jul 2007
    Kansas City,MO
    34
    3
    Quote Originally Posted by HUF View Post
    Here's what gets me though.. I drive around with the a/c on, and both fans are running.. I still see it get up to 225 sometimes...
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Quote Originally Posted by DrCheeto View Post
    Can't comment on this one...my AC has been out from the day one ( I bought it used).
    snydly402 is offline Cadillac Owners Member
    Automobile(s): 1990 sedan deville
    Aug 2007
    Nebraska
    9
    check the a/c condensor to see of the cooling fins are blocked with bugs and gravel, those are common causes and if they are go to a car wash or in your driveway with the engine cold open the hood and spray water from inside the engine compartment outward to clean it off,
  10. Remove Advertisements
