4.1 v8 injector resistance - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
HT4100 4.1, 4.5, 4.9 Discussion, 4.1 v8 injector resistance in Cadillac Engine Discussion; They probably did check the pressure and it showed OK. The pressure however needs to be looked at while the ...
  1. #16
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 4.1 v8 injector resistance
    They probably did check the pressure and it showed OK. The pressure however needs to be looked at while the glitch is happening. This isn't too easy as the gauge has to be secured somewhere where it can be seen during a test drive if the shop has no dyno. If the thing springs a leak the shop might just find out how good their insurance coverage is.
  2. #17
    Cadillac_Slim is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Coupe Deville
    Jul 2013
    Baton Rouge La.
    29
    1
    Bean, I Have a 1983 Coupe Deville 4.1 and my car is doing the exact same thing and i have changed everything you named im so upset - i hope someone can help
  3. #18
    Feb 2003
    california
    69
    6,613
    If you paid to have the pump replaced, you got ripped off! the hose comes in the box with the pump.
  5. #19
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Quote Originally Posted by Cadillac_Slim View Post
    You might try running it with a pressure gauge while driving. Don't remember what you have for an evap cannistor, but if it is saturated or the tank pressure control valve is shot that could be part of your problem. Try taking your fuel tank cap loose. Fuel filter?
    And the original post is 6 years old.
  6. Remove Advertisements
