4.9 Problems at Wide Open Throttle
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 Problems at Wide Open Throttle in Cadillac Engine Discussion; I've got a 91 Deville with 210,000 kms whatever that equates to in miles, and it runs fairly well and ...
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    I've got a 91 Deville with 210,000 kms whatever that equates to in miles, and it runs fairly well and all, tuned up correctly, but at WOT when the engine is warm it wants to give out. I changed the fuel filter, checked the pressure which is between 38 and 42 PSI, cleaned the throttle body, changed the TPS (now has a new one), new cap and rotor, good plugs and wires, and I'm stumped. It's smooth by crusing speeds but when I want to accelerate sometimes I can hardly get it up to 50 MPH, unless I let off the gas a bit then it begins to pick up speed- slowly. When floored, it surges- all of a sudden wants to go but then nearly stalls. It keeps doing this and I can't figure out what's wrong- until I change my head gaskets on my 97 Eldorado, this is my only form of transportation and I don't want to end up stuck somewhere.
    Any ideas on what's causing this problem at WOT? All comments are welcomed.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: 4.9 Problems at Wide Open Throttle
    Restricted exhaust. Cat. Converter coming apart internally. A good muffler shop can determine if Cat. is the culprit.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,128
    Quote Originally Posted by carnut View Post
    Could be. A bad one would rattle when you hit it with something.
    Mar 2007
    31
    2,600
    Found the problem- the simplest thing you can imagine that I overlooked- dirt in the fuel tank around the pick-up screen/sock/whatever it's called. Changed the tank (since the other one was rusty) and cleaned the pick-up with carb-cleaner and an air hose and the car's working perfectly now- no hesitation, no bogging, just pure Cadillac power.
    Thanks for the replies.
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    I had a similar problem in my 93 Deville. Solution (after replacing the FPR and fuel filter which had no effect), was to replace the entire gas tank, fuel pump included. Cost was about $50 for the entire assembly from the junk yard.
  8. Remove Advertisements
