Possible injector leaks?
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, Possible injector leaks? in Cadillac Engine Discussion; Is there any way to tell symptomatically if fuel injectors would be leaking? Rough running? fuel vapor odor? etc etc ...
    zentrade is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 1993 Deville 4.9, 1991 Eldorado Touring Coupe
    Dec 2006
    370
    I know of course they can be tested, But just wondering if there would be any symptoms in driveability or other indications.
    Thanks!
    93 deville 4.9
    cadillac_tech is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX
    May 2007
    Parker , CO
    403
    Re: Possible injector leaks?
    There may be several symptoms. If you have one you're concerned about, it should be addressed that way. A leak could cause a stumble at idle, an extended crank, a dead miss, poor fuel mileage...... To really see if one is dripping, remove the rail from the manifold while it is hot (fuel lines still attached) and watch for a drip.
    Dec 2006
    370
    Thanks! I dont have any of those symptoms except for poor MPG but wouldnt rule out a leaky injector as a contributor to that.
