Ok ive given up on this engine. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
HT4100 4.1, 4.5, 4.9 Discussion, Ok ive given up on this engine. in Cadillac Engine Discussion; Does a reman distributer come with a new cap and coil? It does sound like you have replaced everything in ...
  1. #16
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Ok ive given up on this engine.
    Does a reman distributer come with a new cap and coil? It does sound like you have replaced everything in the ignition except I haven't heard mention of a new coil yet. I'm surprised it doesn't generate some kind of code though. Like someone else said, If it runs fine for a while then you don't need a new engine. I'm sure you are pretty close to solving it. Good luck.
  2. #17
    Callidac der is offline Cadillac Owners Member
    Automobile(s): 1992 DeVille
    Dec 2006
    Atlantic Canada
    26
    Caddilac Dealer wants over $60 an hour to "fiddle with" an OLD Cadillac and it needed a tune up anyway. As for cheap $2 plugs , please send me $100 worth as they are $11 each here for the AC plugs. Coil has been replaced as well. I havent had a chance to get back to the car to go over all the grounds but I did look at the ground near the starter. Is this the main ground cable that goes to the battery or am I looking in the wrong place? Firing order hasnt changed for GM V8s since hmmmmm well since Chevy introduced the 8 in the 50s. 18436572 is ingrained in my memory and we also have 2 other gm 8 cyls with the same order but I will check again.
    Thanks, Chris
  3. #18
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    $10 say if you pull the valve covers off, you will notice that a rocker arm has sliiped or broken from its pivot arm. That just might be your problem...
  5. #19
    lenny lincoln is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2007
    102
    before I paid anyone to turn wrenches on my car I would be stripping the valve covers off to . I would want to make sure its nothing I couldnt fix myself.
  6. Remove Advertisements
