  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: Maitenance Questions, 4.9L 1993 Deville
Old 05-02-07, 12:14 AM
93DevilleUSMC's Avatar
Cadillac(s): 1993 Cadillac Sedandeville
View 93DevilleUSMC's Photo Album
Casino Cash: $14214
Hello,
I had stop-leak tabs put into my coolant reserve tank, and my radiator flushed last November to seal a small leak I had within the tank. The problem hasn't reoccured, although I hear that it is neccessacry to have the above procedure repeated twice a year. Should I have the coolant flushed again soon?
  #2 (permalink)
Old 05-02-07, 08:12 AM
HUF's Avatar
HUF HUF is offline
Cadillac(s): 1995 FWB 88,*** 1991 Seville 175,000 SOLD
View HUF's Photo Album
Casino Cash: $17232
Re: Maitenance Questions, 4.9L 1993 Deville
Originally Posted by 93DevilleUSMC View Post
Hello,
First, never put tabs in the tank. They can plug the hose which connects the reservoir with the radiator neck. Put them directly into radiator instead.
Second, the radiator side tanks are plastic and they are known to crack. You cannot repair a crack. Just replace the radiator. Where was exactly the leak?
Yes , many of us replace the coolant and tabs (Bars Leaks golden seal powder in tubes) every year. The manufacturer suggested every two years though. You do not have to flush the radiator, just drain as much as possible and replace with fresh 50/50 green Prestone/ Distilled Water mix (with coolant supplement - two tubes). I Usually siphone the coolant right through the neck of the radiator with 1/4" tube. That way I get about 1.5 gal of old coolant without making mess.
  #3 (permalink)
Old 05-03-07, 12:16 AM
Casino Cash: $14214
The leak was somewhere on the bottom of the tank. I haven't lost any coolant out of it since November when I had the tabs put in, so I do believe it is working. The radiator's given me no problems, so I don't plan to replace it unless absolutely necessary. Should I perform the siphon/replace coolant procedure ASAP, or wait a couple of months?
  #4 (permalink)
Old 05-03-07, 04:18 AM
HUF's Avatar
HUF HUF is offline
Casino Cash: $17232
The tanks crack usually in the upper portion. Your leak is probably from a connection to the cooling lines.
You do not have to do that ASAP, just a common sense approach.
  #5 (permalink)
Old 05-03-07, 08:30 PM
Casino Cash: $14214
I'll have it looked at again, and probably have what you suggested done this summer. Thank you!
  #6 (permalink)
Old 05-08-07, 02:10 AM
100 100 is offline
Cadillac Owners Enthusiast
Cadillac(s): 1995 Sedan De Ville (4.9 L)
View 100's Photo Album
Casino Cash: $260
I had a leak from the similar location. A big hex nut looking metal part that holds the fitting to the radiator side tank was loose. I really can't describe well, but the oil/ATF coolers have two fittings coming out of the side tank and there are those hex nut looking things holding those fitting to the side tank, thus effectively sealing between the fitting and the tank. When you look at the side tank, I think it is quite trivial what I mean. You may want to check if they are not loose.
Good luck.
  #7 (permalink)
Old 05-08-07, 03:38 AM
Casino Cash: $14214
Thanks for all of the info!
Tags: , ,
1993, 49l, deville, maitenance, questions
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
