Error code 27
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, Error code 27 in Cadillac Engine Discussion; My '85 Eldorado throws an error code of 27 (open throttle switch circuit). I've checked the fuses and replaced the ...
    Lycanthrope is offline Cadillac Owners Member
    Mar 2004
    11
    Error code 27
    My '85 Eldorado throws an error code of 27 (open throttle switch circuit). I've checked the fuses and replaced the throttle position switch, but still receive the error.
    What else can cause this?
    Any help is appreciated.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Error code 27
    Quote Originally Posted by Lycanthrope
    Dude.....you replaced the wrong thing.....LOL
    The throttle position SWITCH is in the idle speed control motor. When you depress the plunger on the ISC motor with your finger you can feel the detent or "click" when you first depress the plunger that is the closed throttle switch or the throttle position switch.
    What you replaced was the throttle position SENSOR.....not the problem.
    Likely the ISC motor will need to be replaced...although some have dissassembled the ISC motor and cleaned and lubed the closed throttle switch contacts with success.....
    Mar 2004
    11
    Re: Error code 27
    Thanks!
    Mar 2004
    11
    Re: Error code 27
    Error fixed with advice from above! ISC motor replacement.
    Thanks again!
  7. Remove Advertisements
