1992 Eldorado 4.9l A/C Help...
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, 1992 Eldorado 4.9l A/C Help... in Cadillac Engine Discussion; Can anyone tell me or describe the area where the orfice tube is located??? Thanks, Chaz....
    theslider is offline Cadillac Owners Member
    Aug 2003
    23
    Thanks,
    Chaz.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 1992 Eldorado 4.9l A/C Help...
    Look at the high pressure AC line just before it enters the HVAC enclosure under the hood next to the firewall... You can usually actually see the divots in the line where the orifice is staked in place to my memory.... The high side line or the hot line is the one coming from the condensor to the HVAC case.... Teh high side line gets real cold real quick across the orifice.... The low side line is the cold one that goes from the HVAC case to the accumulator.
