Error code E31 (93 Deville 4.9L)
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, Error code E31 (93 Deville 4.9L) in Cadillac Engine Discussion; I just pulled the codes for my new Caddy and i'm getting F48 (no biggie i'll put in some refrigerant, ...
    jfolker is offline Cadillac Owners Member
    Mar 2004
    34
    I just pulled the codes for my new Caddy and i'm getting F48 (no biggie i'll put in some refrigerant, i have the tools) and a E31. I know it's the MAP sensor, can anyone tell me where it's located and how to diagnose this further?
    Thanks,
    JF
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Error code E31 (93 Deville 4.9L)
    I think the MAP sensor is mounted off the backside of the throttle body...actually it is the front side of the throttle body....towards the front of the engine or the right side of the car. Follow the vacuum hose off the throttle body to the small, rectangular box like device with a vacuum hose going to it and a wiring connector attached. Check for disconnected lines, wires, holes in the vacuum hose, etc..... If all else is OK then likely replacing the MAP sensor is required. Simple and quick. Nothing to set or adjust. Just R&R the MAP sensor.
    Mar 2004
    34
    Cool, thx for the help. Is there a negative side effect to not replacing it? Probably poor gas mileage and performance...
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Quote Originally Posted by jfolker
    Since the MAP sensor provides the only input to the PCM to calculate the fueling and spark delivery I would say that it is important to the system....yes.... Without the MAP sensor the engine control is very very compromised.
    In most speed density fuel injection systems the engine would not even run without the MAP sensor. Period. You are experiencing one of the benefits of the onboard diagnostic system....the system has detected a failed sensor (a vital one at that) and has warned you with the light and has implemented a backup mode of operation using certain "fail soft" values in the fuel and spark calculation that are designed to keep the engine running despite the loss of vital information until a repair is made. The failsoft values are carefully selected to provide safe operation that will not harm the emission control devices although the emission performance, driveability and fuel economy will be compromised until the repair is made. The fail soft logics and values provide and electronic redundancy in the system to prevent walkhome failures.
    Get the MAP fixed.
    Mar 2004
    34
    Point taken.
    up2ng's Avatar
    up2ng is offline Cadillac Owners Member
    Dec 2003
    New York
    87
    Just in case
    That sensor is in the middle of the rear valve cover, right behind the EGR valve and under the bar that goes between strut towers. It's on it's own pedestal about 4 inches above the motor.
    Mar 2004
    34
    Replaced and the code went away, now for the SERVICE SSS light and the ABS light. Just replaced front hub assemblies.
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    was your engine stumbling to accelarate?like it was jumping around up and down
    Mar 2004
    34
    Not really, the engine seemed to run ok, a bit rich, but now i have an e13 because my o2 sensor is faulty. It gets like 13.5 avg mpg.
    If your car is doing that, I wouldn't rule it out, bad MAF and MAP sensors (MAF=Mass Air Flow, MAP=Manifold Absolute Pressure; Different cars use diff. methods) will cause a stumble in the car.
    THanks,
    jf
  12. Remove Advertisements
