HT4100 Misfire Question
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, HT4100 Misfire Question in Cadillac Engine Discussion; Hi everyone-- So my car (85 Deville with 32,000 miles) runs perfectly now for the most part except an issue ...
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Hi everyone--
    So my car (85 Deville with 32,000 miles) runs perfectly now for the most part except an issue that still continues to plague it that I've finally been able to rule out a few issues as the culprit:
    Basically, my car runs just fine now around town and at anything up to about 3/4 throttle and 3500 rpms. After that, if I really lay into it, I'll get popping in the intake, like an exhaust valve is sticking or not sealing. There's no ticking ever, so I don't think it's a lifter...but what do you think? Bad valve spring? Rocker arm pivot? Bent pushrod? Flat cam?
    I have an early 85 model with the more flimsy rocker arm pivots so I was wondering what the symptoms are of a car with such a problem.
    As I said, the car has good power up to about 3500 rpms, but the compression is low on one particular cylinder (#7).
    Timing is spot on (jumps around a bit because of the low compression, but not much), all new ignition system (the entire thing--distributor, plugs, wires, etc.).
    Any opinions?
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: HT4100 Misfire Question
    First guess would be fuel supply issues. Fuel pump output? fuel pressure regulator, fuel filter ?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    I agree, the fuel filter is probably original! if an engine runs lean, it will pop thru the air intake. Change the filter. You can verify if the filter was plugged by simply blowing thru it once removed.
    Jun 2005
    Michigan
    668
    I already changed the fuel filter when I got the car and the pressure is always a good 12 psi. It's definitely a mechanical issue. Both injectors work perfectly too.
    Nov 2005
    368
    Does it exhibit the same symptoms just revving in neutral or do they appear only under load?
    Jun 2005
    Michigan
    668
    Good question. If I really rev it in neutral, it'll do it too. It's definitely some mechanical issue...catalytic converter has also been changed, so it's not a back pressure issue.
    Nov 2005
    368
    Does it appear worse under load or begin at lower RPMs?
  10. Remove Advertisements
