car runs too rich didnt pass smog
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, car runs too rich didnt pass smog in Cadillac Engine Discussion; i have a 90 4.5 fleetwood fwd and it is running too rich. wont pass smog because of it. i ...
    bshizzle is offline Cadillac Owners Member
    Automobile(s): 90 4.5 fleetwood fwd
    Sep 2005
    8
    i have a 90 4.5 fleetwood fwd and it is running too rich. wont pass smog because of it. i have most injectors replaced couple of years ago. did a tune up o2 sensor changed. is there anything someone could recommend before i take this to a mechanic shop and blow 100's of dollars.
    my car also qualified as a gross poluter. the numbers it failed was at like 600 but was suppose to be at 120 or under.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: car runs too rich didnt pass smog
    maybe a bad fuel pressure regulator?
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    Here's the list from the FSM for diagnosing a rich condition:
    Run OBD diagnostic - any codes?
    Double check oxygen sensor parameters and connections
    if oxy sensor is within parameter value 0.00 to 0.63 V:
    1) Check for restricted air cleaner or thermac valve operation
    2) Check EGR operation
    3) Check fuel pressure
    4) Check for injector leaks
    5) Check for vacuum leak to MAP hose
    6) Check purge canister for proper operation
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    I just tried seafoam, says on the can it'll help pass emissions test. It cleans carbon out of the engine.
    I would say o2 was at fault if was it replaced before the injectors? If it was one after the injectors it may be fine, Also was the car warmed up when tested or still cold?
  7. Remove Advertisements
