E055 OBD1 Code
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, E055 OBD1 Code in Cadillac Engine Discussion; The code is for throttle out of range. My question is, is there an easy fix for this or is ...
    CadillacDonn is offline Cadillac Owners Member
    Automobile(s): '92 coupe deville
    Mar 2007
    wisconsin
    34
    9
    QuestionE055 OBD1 Code
    The code is for throttle out of range. My question is, is there an easy fix for this or is the throttle body going? any advice or replies will be appreciated thank you.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: E055 OBD1 Code
    Likely due to a bad throttle position sensor, stuck EGR valve, or plugged EGR tubes in the throttle body.
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    Re: E055 OBD1 Code
    See the earlier thread in this forum entitled:
    Throttle Position Sensor Misadjusted
