4.1 oil capacity
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, 4.1 oil capacity in Cadillac Engine Discussion; Can anyone tell me what the correct oil capacity for a 4.1 is? The service manual says it is 4 ...
    CoupeDevilleRob's Avatar
    CoupeDevilleRob is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 Coupe deVille
    Jan 2004
    Eastchester, NY
    32
    807
    4.1 oil capacity
    Can anyone tell me what the correct oil capacity for a 4.1 is? The service manual says it is 4 quarts with or without the filter. How can it be the same with or without filter change? I find this fact hard to believe, I'd like to understand how this can be. My dad and mechanic insist it takes 5 quarts. They've been using that much for the past 15 years and 50,000 miles and the engine runs fine, so maybe 5 quarts is correct.
    I also have another side question about the dip stick. How the hell do you read this thing? I has an add one quart range, then a full range. Is it full at the lower or upper part of the full range or is it full when it reads anywhere in the full range? Personally I think it's a really bad design. Any help on either question would be greatly appreciated.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 4.1 oil capacity
    Quote Originally Posted by CoupeDevilleRob
    That engine requires 5 quarts to my recollection when the filter is changed. The thought was that the filter volume is relatively small so 5 quarts puts it in the operating range regardless. No one realized that people would be so obcessive over oil level.
    Thanks for the critique on a 22 year old dipstick design....LOL
    Put 5 quarts in at the change, start the engine and let it idle and then shut it off and check the stick. That will give you some insight on how the stick reads. If you KNOW you put 5 quarts in then that will be the baseline on the stick for reference....
    Jan 2004
    Eastchester, NY
    32
    807
    I put in 5 quarts and it reads at the bottom of the full range. Thanks for the help!!
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    BTW....what "manual" said to use 4 quarts...???? The factory service manual says 5 quarts as did the owners manaul to my recollection.....
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    I use 5 qts in the 4.1 in my '85 Fleetwood Brougham. I think coupedevillebob is referring to the chilton book, because my stupid chilton says "use 4 w/out filter change".
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Quote Originally Posted by AElayyat
    One MORE reason that Chiltons make good kindling.....
    AElayyat's Avatar
    Feb 2004
    So. Cali
    35
    1,135
    Quote Originally Posted by bbob
    That's why I am still looking for the Cadillac manuel on ebay but no luck.
    waynev is offline Cadillac Owners Member
    Mar 2004
    Dallas
    Jan 2004
    Eastchester, NY
    32
    807
    I was referring to the Cadillac service manual. The Chilton book says the same though.
  12. Remove Advertisements
