Results 1 to 4 of 4
Thread: 86 Fleetwood engine swap
    kunta604 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    4
    Hi,
    I am new to this forum and very new to cadillacs. I was lucky enough to receive a 1986 Fleetwood with a perfect interior and exterior. The trouble is the engine sounds like it will die any day. The Fleetwood is not ready to go to car heaven. I have a 305 engine out of a 88 GM PU and was wonder if the engine mounts are compatible with the Fleetwood. I was also wondering if my tranny should be replaced?
    Thank you experts for the help.
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    Re: 86 Fleetwood engine swap
    Is this a front wheel drive or rear? Fleetwood made bodies for both in '86.
    What exactly is the engine doing that makes you think it's dying?
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    I agree. If this is a RWD Fleetwood, you likely have an Olds 307 in the vehicle--and this would be the engine pulled from an 88. See if the oil fill tube is left of the thermostat. If so, you have an Olds engine, not a Chevy 305. This forum is for HT4100, 4.5, and 4.9 Cadillac V8s so you might want to try the other "5.0 and 5.7L" forum.
  5. #4
    Apr 2007
    4
    Thank you guys for the fast replies.
    My Fleetwood is a RWD and the oil tube is left of the thermostat. I will check the 5.0 and5.7L forum.
    Thanks once again!
  • You may not post replies
