Removing EGR valve - 4100
Results 1 to 15 of 15
HT4100 4.1, 4.5, 4.9 Discussion, Removing EGR valve - 4100 in Cadillac Engine Discussion; I've exhausted every wrench in my modest tool box - what can I use to reach the bolts on the ...
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    I've exhausted every wrench in my modest tool box - what can I use to reach the bolts on the EGR valve in a 4.1?
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: Removing EGR valve - 4100
    For my 4.9 I took a cheap 13mm combo wrench, torched it near the box end, bent it 90 degrees, then used a vice grips to turn it. If your 4.1 has the same EGR setup, this should work.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    I have 3 suggestions that I use:
    1) Crows feet wrenches (available at any auto parts store, I believe you need 13mm, but don't quote me on that).
    2) Stubby wrenches (little, short, fat wrenches).
    3) Distributor wrench.
    I think I was able to get one of the bolts pretty easily with just a 13mm open end wrench that wasn't too long.
    Jun 2005
    Michigan
    668
    Can you tell me what the top nipple on the EGR solenoid connects to, if anything (looks like it just has a little filter on it in the picture on your website)? I know the bottom one is connected to the EGR.
    Jun 2005
    Michigan
    668
    One more thing--
    If you do buy the crows feet wrenches, purchase a 1/4" drive extension, and two 1/4" to 3/8" drive adapters. I'm assuming your socket set is 3/8" drive.
    You'll find that the thinner extension allows you to get closer to the EGR bolts. Depending on the manufacturer, some 3/8" drive extensions are quite fat, and hit the EGR valve body when you try to use them...not permitting you to reach the bolt with a crow's foot.
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    That nipple with a filter doesn't connect to anything. It is a vent or more accurately, ambient air intake. The piece of foam is there to filter out any debris from geting ingested. The solenoid cycles between vacuum and ambient air in order to acheive a variable vacuum to be applied to the EGR valve.
    Peteski
    gdwriter's Avatar
    gdwriter is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2010 CTS (Elvis) 1964 Impala (Betty) 1991 Miata (Dolly)
    Aug 2005
    Independence, OR
    50
    14,310
    Well, since I don't have much beyond a basic socket set, I ended up taking off the throttle body on my 4.9. After that, it was easy to get to the bolts on the EGR valve with an open-end wrench. It also gave me a good opportunity to clean out the tubes in the throttle body.
    Of course, reconnecting all the vacuum lines to the throttle body was a bitch. Considering the age of my car, it should come as no surprise that the rubber connectors on several were brittle and had to be replaced. And dummy me, I couldn't figure out what happened to the line connecting the MAF sensor to the throttle body.
    Fortunately, there's a '93 DeVille up the road from me and the owner was nice enough to let me look under his hood. It turned out the vacuum line had gotten turned around and was wedged down towards the intake manifold. Once I pulled it out and reconnected it properly, everything was fine.
    As I've mentioned here before, Mr. Goodwrench I'm not.
    Jun 2005
    Michigan
    668
    On my 4.9 car, and even perhaps on this 4.1, I used to take the throttle body bolts out and just lift it up a few inches to get more wrench clearance without disconnecting anything else. Worked just fine.
    noahsdad's Avatar
    Jun 2005
    Michigan
    57
    1,296
    Thanks guys - lots of good ideas here. I'll let you know the results.
    biggeazy-e is offline Cadillac Owners Member
    Jul 2004
    39
    I replaced one today, removed TPS and it was pretty easy to get to the frontmost bolt...
    Melrose is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Deville, 1987 Eldorado
    Apr 2005
    North Carolina
    109
    Bought either a set of claw foot wrenches or the correct size swivel socket to solve the problem. Another solution would be the correct stubby wrench.
    It is a toughie to get in there.
    Apr 2005
    North Carolina
    109
    Apr 2005
    North Carolina
    109
    A stubby chinese wrench from Costco, or the swivel socket 12 0r 13mm from Craftsman is the only way to get it out. A plain socket with a swivel will not clear the housing.
  16. #14
    rzq6c8 is offline Cadillac Owners Member
    Automobile(s): 1990 Fleetwood
    Apr 2005
    Michigan
    3
    I'm going thru the same thing with the brittle connections. Where did you find the parts? I'm having a heckuva a time searching for them. Can you replace just the connector or do you have to buy the vacuum tube with the connectors already on them?
  17. #15
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    Quote Originally Posted by rzq6c8 View Post
    Sorry I didnt see this earlier. If you are trying to just replace broken plastic lines then get some rubber tube and use a bit of glue to piece it together. Works good to just slip each end of the plastic into the rubber hose and make sure no glue blocks the way.
    I am not sure what to do if you need to replace actual connectors, You may have to rig something up.
  18. Remove Advertisements
