serious help needed
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, serious help needed in Cadillac Engine Discussion; Ok i have a 1992 sls. was driving down the road then tried to get onto freeway. got up to ...
    thepokerprofessor is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2007
    3
    serious help needed
    Ok i have a 1992 sls. was driving down the road then tried to get onto freeway. got up to 50 then started to slug, stepped on it......it died!!!!!
    I have done a static timing check looks close(i am leaning toward a skipped timiong chain) i have fuel into the intake can smell it and pressure looks good. i have spark more than once it sparks the whole time you crank it. It will kinda want to start if you floor it, but it dies before you can release the key. no codes either, did the warm off button thingy. i also changed the fuel filter. the cap and rotor i cleaned off, but those wont cause a car to just quit, this is the biggest issue it just stopped running.... can anyone help, if i get this up the best answer i will try to get them a gift carx to somewhere for the help. thanks. And if you can figure it out and it not be the timing belt i can send you my wife for a night too............lol.
    Pckstude is offline Cadillac Owners Member
    Mar 2007
    51
    Re: serious help needed
    does the engine turn over smoothly? or does it backfire, or seem to fire against itself, as in turning over then it slows down because one of the cylinders fired? If it turns over smoothly and just seems to fire once in awhile it probably isn't the timing belt. How many miles are on the car? A crack in ur distributer cap can cause strange things to happen, and u may not even be able to see the crack with ur naked eye. Of course u can always put the engine crank pulley on top dead center for the no. 1 cylinder and see if the rotor is at the number one post on the cap. This will tell u for sure whether or not it's ur timing belt. I can't help u past that as I don't know much about the caddilacs. Good luck, and u can keep ur wife. I already have one, and one is enough! lol
    Callidac der is offline Cadillac Owners Member
    Automobile(s): 1992 DeVille
    Dec 2006
    Atlantic Canada
    26
    Sparks the entire time you are turning it over? If this is the case you have ignition issues. you should get 1 spark from each wire every time the engine makes 1 revolution. My question is.................does the 93 have a distributor? If so remove the cap and have a look. If it has no dizzy then its not within my abilitys.
    Also the ignition mod failure mode is to just quit. The module can be removed and tested at some auto parts places.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    All 4.9s have distributors. Can you describe the symptoms better? If the engine "pops" when cranking, you likely have a bad timing chain (not belt) or timing gear. This is rare, however, on 4.9s.
    Are you getting enough fuel pressure at the rail? You need about 35 psi to even get the injectors to work, so if your pressure gauge reads 25, you're going to likely be in need of a fuel pump.
    Mar 2007
    3
    ok heres the update, i changed the IGN mod, static time is dead on so i ruled out the timing chain, replaced the fuel press regulator, i have 150psi in front 4 cyls(with that i didnt go to the back)i replaced the PCM(no change but different codes. the only code the car had at the original problem was a eo31, which is a shorted map sensor circuit. So i ordered a map sensor. Now can anyone help me out from here? I am desperate, i have spent the last 4 days trying to diagnosis this issue and am at my witsend.. Thanks from minnesota
    Mar 2007
    3
    ohh yea i have 45 psi at the rail for fuel pressure i had that all the time i meant to put 48 not 28
    Dec 2006
    Atlantic Canada
    26
    Is it still sparking "the whole time" you crank it?
    Melrose is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Deville, 1987 Eldorado
    Apr 2005
    North Carolina
    109
    If you check the forum, you'll see others are having the same problem, and believe me I had it once in a 1993 Deville and I had to get rid of the car. I think there is an inherent defect in the 4.9 and Cadillac refuses to own up to it. And it is apparently the same thing--no codes !! Good luck !! It appears around 60-80k It is dreadful !!
    Yagos is offline Cadillac Owners Member
    Jan 2007
    11
    hmm, i am no mechanic or anything of the sort.
    but could it maybe be the Cat.
    My car did a similar thing and it turned out the Cat was blocked
    Just a suggestion
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Something tells me your problem is inside of distributor. Could you please post the picture of your wife?
    lol
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    OP,
    Have you checked the fuses for the fuel injectors? Should be in the fuse box under the hood.
  14. Remove Advertisements
