View Poll Results: Are There Any Other V8-6-4 Owners Out There?
Voters
1. You may not vote on this poll
  • Yes
    1 100.00%
  • No
    0 0%
Results 1 to 3 of 3
Thread: Loss of Power on Power Window 1981 Coupe Deville
    varelap is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    3
    I have a 1981 Coupe De Ville V8-6-4 which I am trying to restore for my son. I was replacing the window channels, and my power windows stopped working. I checked the wires with an ohm meter and there is no power on the wires leading to and from the power window switch. The windows are stuck in the down position. I tried supplying power to the switch just to get the windows up, but this resulted in an arc. I am assuming I have a ground somewhere in the wiring, but I don't have a wiring diagram. Can anyone help me locate a diagram or help me find where the fusible links are in this car?
    Any help would be greatly appreciated!
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,287
    Re: Loss of Power on Power Window 1981 Coupe Deville
    Check for broken wires in the door hinge area where the harness flexes. Pull on the wires and if you see one stretch, that's it.
    Don't mess with Binky Bear!
    Feb 2007
    3
    I will do that this evening and let you know what I find.
  • You may not post replies
