Eldorado, electrical problem
Results 1 to 4 of 4
Electrical Technical Information Discussion, Eldorado, electrical problem in Item Specific Cadillac Discussion; 92 eldorado, I have asked this question once before, here we go again, I cant shut off the electrical on ...
    jjyn's Avatar
    jjyn is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldorado Touring Coupe , 1992
    Jan 2007
    Maine
    13
    92 eldorado, I have asked this question once before, here we go again, I cant shut off the electrical on the eldorado. I turn the key off and the engine stops but all the electrical stays on. heater,dash lights etc. etc. I was told to replace the electrical switch, and it didnt make any difference. I tryed manually shutting it off right at the switch, but that didnt work either, i have also tryed varius fuses , but i am back to guessing again. Any suggestions i will try , if you have any other ideas, sincerly , JJ.
    97STS4ME is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Seville STS, Black
    Aug 2005
    Charlottesville, VA
    147
    Re: Eldorado, electrical problem
    I know the radio will stay on until the door is opened on alot of Caddys, but ive never heard of everything staying on... Tried replacing the ignition switch?
    jjyn's Avatar
    Jan 2007
    Maine
    13
    yes i replaced the ignition switch at $109.00 but it didnt help. i even left everything plugged in and tryed the switch manually without using the key . thinking of checking out the rack next, mayby ? who knows...... I think i will sell this when its fixed........ gettin very dissapointed with these electronics. kinda sad really, the car is in awsome shape............
    Feb 2003
    california
    69
    6,627
    Try replacing the RAP relay (retained accessory power). The relay should keep things on for approx ten min if no door is opened.
  7. Remove Advertisements
