Electrical wiring diagrams
Results 1 to 9 of 9
Electrical Technical Information Discussion, Electrical wiring diagrams in Item Specific Cadillac Discussion; im working on a 1966 cadillac calais as a project and ive replaced the solenoid, the coil, the plugs, wires, ...
    Pauliwogg is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    6
    im working on a 1966 cadillac calais as a project and ive replaced the solenoid, the coil, the plugs, wires, distributor cap, rotar, and points. and i cant figure out why it wont start when i turn the key. i know the starter works because i used an ignition switch interupter and the starter motor turned. any suggestions?
    97STS4ME is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Seville STS, Black
    Aug 2005
    Charlottesville, VA
    147
    Re: Electrical wiring diagrams
    When you turn the key does the starter turn over, but the engine wont fire? Or does it do nothing at all?
    Feb 2007
    6
    it does nothing at all
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Starter solenoid?
    Feb 2007
    6
    starter solinoid is good. new solinoid
    Nov 2005
    368
    Are you getting power to the solenoid when the key is in the start position? Are both battery cables good? Do the lights work?
    Feb 2007
    6
    The lights work and the Horn works and the battery cables are brand new i just replaced both of them. i dont think im getting power to the Solinoid when i turn the key.
    Feb 2007
    6
    i ordered a new igntion switch and am installing it this weekend
    Feb 2007
    6
    i pulled the starter out and had it tested. it was bad so i ordered a new one that will be here by saturday and then hopefully everything will work.
  12. Remove Advertisements
