Pulling Codes on 1989 Cadillac Fleetwood
Results 1 to 8 of 8
Electrical Technical Information Discussion, Pulling Codes on 1989 Cadillac Fleetwood in Item Specific Cadillac Discussion; Does anyone know how to pull the codes? This car does not have the fuel data center. Is it still ...
    97d'elegance is offline Cadillac Owners Member
    Feb 2004
    Orlando
    43
    52
    Does anyone know how to pull the codes? This car does not have the fuel data center. Is it still accessed through the climate control center? If so, what buttons do you push simultaneously?
    Thank you!
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Pulling Codes on 1989 Cadillac Fleetwood
    Yes, you push OFF and WARMER on the climate control to get the codes.
    Feb 2004
    Orlando
    43
    52
    I tried that ... it didn't do anything.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    I thought all of those Fleetwoods had the fuel data center stuff
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Would this be a RWD Brougham? Then you might need to deal with blink codes.
    Feb 2004
    Orlando
    43
    52
    Yes, this is a RWD brougham. What are blink codes and how do I pull them?
    Thanks!
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Look under the dash for the ALDL, the 12 cavity diagnostics connector. Get a paperclip, and with the ignition on, jump pins A and B. They are the two pins at the top right of the connector. The Check engine light will begin to blink. it will first blink a code 12 by blinking once, short pause, then two successive blinks. There is a longer pause between codes. If you post the codes, I'll look them up for you.
    Spock's Avatar
    Spock is offline Cadillac Owners Fanatic
    Dec 2003
    Alberta, Canada
    437
    Whoa! I've been trying the warmer and off with my 86 rwd and it wasn't working. Switched the ECC with an american part and it gave me gibberish.
    I shall try the paper clip too! As after I cleaned my engine with diesel it's been giving me the check engine light.
  11. Remove Advertisements
