Where is turnsignal flasher on 99 Deville?
Results 1 to 2 of 2
Electrical Technical Information Discussion, Where is turnsignal flasher on 99 Deville? in Item Specific Cadillac Discussion; I've read the other posts. They seem to be moving this thing around. I found the 4-way flasher unit but ...
    a2wheelerte is offline Cadillac Owners Member
    Feb 2004
    I've read the other posts. They seem to be moving this thing around. I found the 4-way flasher unit but not the electronic turnsignal flasher unit.
    Feb 2004
    Re: Where is turnsignal flasher on 99 Deville?
    I found it. Under the dash as you are looking up and back at the front seat, it is to the right of the steering column and to the right of a support bracket. Very hard to see. If you are sitting in the driver seat it would be about straight forward of your kneecap.
