climate control center jumps from 85 to 90 is this normal?
Results 1 to 4 of 4
Electrical Technical Information Discussion, climate control center jumps from 85 to 90 is this normal? in Item Specific Cadillac Discussion; Is this supose to be like this? I dont remember exactly if it went 85,86,87,88,89,90? Thanks for any info . ...
    93sdeville4.9m's Avatar
    93sdeville4.9m is offline Cadillac Owners Member
    Nov 2003
    62
    Questionclimate control center jumps from 85 to 90 is this normal?
    Is this supose to be like this? I dont remember exactly if it went 85,86,87,88,89,90? Thanks for any info . If I change the egr valve will it get rid of a code 048? Thanks for any help in advance.
    Big Jim is offline Cadillac Owners Member
    Dec 2003
    West of Denver, CO
    44
    Re: climate control center jumps from 85 to 90 is this normal?
    Yes, it is normal. You get one degree changes over the "normal" range but at the ends, it jumps by 5 degrees at a time. The same thing should happen on the cold end.
    airbalancer's Avatar
    airbalancer is offline Cadillac Owners Connoisseur
    Sep 2003
    Cobourg Ontario
    59
    1,303
    My 99 STS does the samething at top and bottom end .29C to 32 C
    Nov 2003
    62
    TalkingRe: climate control center jumps from 85 to 90 is this normal?
    Thanks fellas. Glads its normal. Whew!!! Thought somethin else went haywire.
  7. Remove Advertisements
