My brake light goes out!
Results 1 to 5 of 5
Electrical Technical Information Discussion, My brake light goes out! in Item Specific Cadillac Discussion; 1995 DeVille. When I hit the brake pedel (while my lights are on), the right brake light goes out. I ...
    peteypablo is offline Cadillac Owners Member
    Feb 2004
    6
    1995 DeVille. When I hit the brake pedel (while my lights are on), the right brake light goes out. I already replaced the bulb. Can anyone tell me what the problem is? Thanx
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: My brake light goes out!
    Does that particular bulb light when the brake is depressed and the parking lights are off?
    Feb 2004
    6
    Quote Originally Posted by DaveSmed
    Yes.
    BUILDINGCTSAMG is offline Cadillac Owners Connoisseur
    Mar 2003
    Atlanta Ga/Mclean Va
    32
    1,753
    Sounds very odd....has to be some sort of wiring issue........I would normally say check ur fuses but i dont think this could be the cause......might be though
    Spock's Avatar
    Spock is offline Cadillac Owners Fanatic
    Dec 2003
    Alberta, Canada
    437
    Take apart your brake light housing and inspect it to see if the two metal strips are touching each other. When replacing or taking one out, one will flip up; they'll contact and release the smoke out of your bulbs.
  8. Remove Advertisements
