alarm help
Results 1 to 7 of 7
Electrical Technical Information Discussion, alarm help in Item Specific Cadillac Discussion; ok i dont knwo what it is but when i get in to me car i press the key pad ...
    Xmugsyx's Avatar
    Xmugsyx is offline Cadillac Owners Member
    Dec 2003
    NyC
    35
    93
    alarm help
    ok i dont knwo what it is but when i get in to me car i press the key pad it shuts off the alarm i go and try to start it it disabaels the starting and i have to wait 3 mins to try again but why is it not starting when the alarm is off and i notice that the sucrity light comes on here and then when i am driveing any one help me witht his one ??? its a 94 eldorado
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    Re: alarm help
    It sounds like the pellet in the key or the sensor in the ignition lock for it might be worn out. Did you try using another key to see if it has the same problem?
    DannyR619's Avatar
    DannyR619 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Aug 2003
    San Diego
    21
    Re: alarm help
    I had this same problem. Its the the VATS system, in the key hole, thats not making good contact with the little resistor on your key. I took it in to the dealer and it was about $350 to replace the ignition cylinder, and two new keys(ugly GM one, not the gold ones with the cadillac emblem). If you do go to the dealer tell them straight off just to replace the ignition cylinder, this way you save the $84 diagnosis fee. Search this forum for "wait three minutes," some people had other fixes that worked for them.
    philthy's Avatar
    philthy is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2004
    47
    46
    Re: alarm help
    Try cleaning the keys or try your spare set first, or bypass the system. I just had mine bypassed. All you have to do is get resistor(s) that match the resistance of the chip on your key. There are two very small wires encased in a tube that looks a lot like another wire (mine was orange) leading from the ignition switch. cut the wires and put the resistor across them. I had an friend's brother who does auto alarms do it and he only charged $50 to do it at my house. He had to come out and do it because I put it off until the car decided not to start at all. While he was there, he put in a remote start system. Don't delay, you never know when the car will decide to cut off completely instead of making you wait a few minutes. Mine died on the street during a snow storm, and I had to push it into the garage so he could work on it !!
    DannyR619's Avatar
    Aug 2003
    San Diego
    21
    Re: alarm help
    i heard about the bypass option, but i decided to just replace it because i wanted the extra layer of security. But i could find the 2 wires to put the resistor between anyways.
    Xmugsyx's Avatar
    Dec 2003
    NyC
    35
    93
    Re: alarm help
    so i have to open the steering colom to bypass it if that the fact i should just replace it dose any one know if caddie dealer might just have them in the parts departmen
    Jun 2003
    Canada
    6,464
    Re: alarm help
    This is what I was talking about in the other post. I think the wires should be pretty easy to get to because I've never read anything about anyone digging into their steering column to do it.
  10. Remove Advertisements
