i want to disable traction control on my 94SLS,.
Results 1 to 4 of 4
Electrical Technical Information Discussion, i want to disable traction control on my 94SLS,. in Item Specific Cadillac Discussion; can anyone help me how do you disable traction control on a 94 SLS ?...
    coffeebreak1 is offline Cadillac Owners Member
    Jan 2004
    north carolina
    50
    32
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: i want to disable traction control on my 94SLS,.
    Read the thread entitled "Traction Control Sucks" under the Northstar Performance and Technical section. That may help you.
    STS2NV is offline Cadillac Owners Member
    Oct 2003
    18
    Hi
    All you have to do is pull the fuse for the abs....this will disable the traction control....but also the abs
    El Dobro's Avatar
    Sep 2003
    1,471
    Go through the diagnostics to disable it. This way everything still works the way it's intended.
  7. Remove Advertisements
