93 sts starter
Results 1 to 3 of 3
Electrical Technical Information Discussion, 93 sts starter in Item Specific Cadillac Discussion; Hi I have a 93 sts with a 4.6 north* and I live in Canada. Sometimes with the wind chill ...
    STS2NV is offline Cadillac Owners Member
    Oct 2003
    18
    93 sts starter
    Hi
    Sometimes with the wind chill temp is getting down to minus 35.
    My problem is when the temp is below about minus 5 the caddy will not start, as in the starter motor does not even turn.When the temp goes up again it starts no problem, is there a relay somewhere that may sticking?
    Thanx for any help
    coffeebreak1 is offline Cadillac Owners Member
    Jan 2004
    north carolina
    50
    32
    Re: 93 sts starter
    try a good deep cycle battery 1000 cold cranking amps. or better.
    Quote Originally Posted by STS2NV
    Hi
    Thanx for any help
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    Re: 93 sts starter
    There is a 'starter enable relay' under the trim and carpet...about forward area...of the lower drivers door side trim. Very hard relay to find in warm weather! Its inside the harness plastic protector.
    Geezz....I dont miss that cooolld weather!
    Logan
    www.airbagcrash.com
    www.logandiagnostic.com
