cadi window motors
Results 1 to 6 of 6
Electrical Technical Information Discussion, cadi window motors in Item Specific Cadillac Discussion; 83 cadillac coupe de ville.......window motor sometimes don't work.... anything you can do besides kick the door panel?...
    harborareaphil's Avatar
    harborareaphil is offline Cadillac Owners Member
    Jan 2004
    45
    16
    Questioncadi window motors
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: cadi window motors
    When it does work, does it go up slowly?
    Jan 2004
    45
    16
    WAITED FOR THE SUN TO COME UP, AND WENT OUT AND STARTED IT AND IT ROLLED RIGHT UP
    ITS KINDA SLOW WHEN IT DOES WORK.........BUT ALL THE CADI'S I'VED OWNED ROLLED UP SLOWLY
    86DeVille is offline Cadillac Owners Member
    Jan 2004
    5
    Did you ever find out what to do beside kicking the door panel? Is that how to open it? I can't figure it out. I want to get the thing open but don't know how to start. Anyone know how to get into the works of an older ('86) Caddie DeVille electric window?
    bob2231's Avatar
    bob2231 is offline Cadillac Owners Enthusiast
    Sep 2003
    Tampa, Fl
    55
    520
    Quote Originally Posted by harborareaphil
    Usually this is the first sign of a dying motor. You may want to replace it before it sticks at a really bad time.
    Bob
    97Deville's Avatar
    97Deville is offline Cadillac Owners Member
    Feb 2004
    Ontario, Canada
    56
    Had an 81 Eldo that behaved the same way, kick the door panel near the hinge, to make it work. It was frustrating because i would pull the door panel off, and the window would start working, put the panel back, quit working. It was a bad ground, what worked for me: loosen and re-tighten the regulator mounts, one at a time. Also reminded on another thread, is that the power to the passenger doors also goes though the driver door. A bad switch in either place, will fail to supply power.
  9. Remove Advertisements
