Need 98 STS front seat heat module
Results 1 to 13 of 13
Electrical Technical Information Discussion, Need 98 STS front seat heat module in Item Specific Cadillac Discussion; Trying to get my heated seat working....Looking for a heated front seat module for a '98 sts. Anyone have an ...
    Guy,mn.usa is offline Cadillac Owners Fanatic
    Sep 2005
    136
    Trying to get my heated seat working....Looking for a heated front seat module for a '98 sts. Anyone have an extra one?
    Sep 2003
    Metro ATL
    4,854
    Re: Need 98 STS front seat heat module
    You have an extra one if you are talking about the module that controls the heating operation. Swap the other side module for the one that is not working.
    Have you done continuity tests on the seat cushion and seat back heaters as well as the thermistor??
    Sep 2005
    136
    Hate to take the passenger side as it rivited and working great! Is there one in the back seat I could use? And No I have not done any testing of the elements....how do you do that?
    Sep 2003
    Metro ATL
    4,854
    Based on the wiring diagrams and the connector arrangement, all four heated seat positions use the same control module but I don't know that for a fact. The rear seat modules are behind the rear seat back. Might be easier to swap one of those (good idea!).
    Also be aware there are 10 A fuses under the rear seat cushion for each seat position labled like HTDST LF, HTDST RF and so on.
    If you are experienced and comfortable with a VOM, I can give you the connector description and pin identification (OK, GM calls them cavities) for a continuity check of the heater elements and the thermistor.
    Tommy Deville's Avatar
    Tommy Deville is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    are there fuses under all cadiilacs 97-99 model year? my deville has fuse boxes in the trunk
    dormaj is offline Cadillac Owners Member
    Jul 2004
    10
    Jim D - I've got the same problem with my '99 STS RF seat. I checked the fuse under the rear seat and it is fine (they really should put a fuse puller in that box).
    Please explain (or send me info on) how to check the continutity on the seat back and cushion.
    Thanks!
    - Jeff
    Sep 2003
    Metro ATL
    4,854
    Happy to do that but I am not at home and it will be Wed. or Thur. before I can post the pin-outs. Someone else might be able to provide the information before I have a chance.
    Sep 2003
    Metro ATL
    4,854
    Jeff:
    If you still need the pin-outs, I'm good to go.
    mastertech is offline Cadillac Owners Fanatic
    Jul 2004
    St. Clair Shores, MI
    300
    The solution to both of your problems will be the seat cushion element...if you attempt to remove yourself, you will notice a burn mark in the element where it failed....very common for both front seats...it is highly unlikely you will need a module, as I have personally replaced well over 200 elements, and no modules for this failure...good luck.
    dwardleworth is offline Cadillac Owners Member
    Mar 2006
    1
    what is the approximate cost for replacement of a seat cushion element? I have power to the switches - but no heat in the seat, sounds like this is the right fix.
    rolingcoffe is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS
    Jul 2005
    22
    Hi. I was in the same boat as you folks up until yesterday. I have a 99 STS and the drivers seat heater quit working. I swapped the module between the front seats (easier than it looks at first) and found it was not the module. SO i ordered an element from Gmpartsdirect for $75. I took the base out of the drivers seat and pulled the cover off. (Note: probably didn't need to detach the whole base, it would be easier just to pull the cover off) On the under side of the cover I was suprised to see not 1 but 3 different heating elements. The center element had an easy to see burn mark and a broken/scorched wire. I was pretty pissed as I had spent $75 on the side element when it was the center element that was broken. Not only do they not tell you there are multiple elements they have a no return policy... Anyway, I couldn't find the center element so I said "**** it" and soldered the wire back together. (after removing the scorched part of the wire). Duct taped the wire back in place, and put the seat back together. Guess what... it worked. Didn't need any new parts, just a little solder. Good luck!
    CentreIce is offline Cadillac Owners Member
    Automobile(s): 1998 STS
    Feb 2007
    Toronto, Ontario
    16
    Quote Originally Posted by rolingcoffe View Post
    How does one go about pulling the cover off the seat?
    CaptainFishpond's Avatar
    CaptainFishpond is offline Banned
    Automobile(s): 99 DeVille (Grace Slick)
    Jul 2006
    Cleveland
    30
    333
    I might have one at work.
    Ill check.
  16. Remove Advertisements
