I have a 1993 Sedan deVille which is having Anti Lock issues. Part of the diagnosis requires me to remove the main anti lock relay which is found in the maxi fuse/relay center under the hood. I would like to know which relay the main anti lock relay is and how to remove it. It appears that the relays should just slide forward but that is not seeming to be the case.
