Results 1 to 1 of 1
Thread: All climate switches
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    63
    161
    Hello everyone, The climate fan switch and the vent discharge switch sometimes wont
    connect. sometimes they work perfectly, the fan switch always works going higher but every once in a while acts reluctant to lower speed, after a couple of touches with negative results I just use the steering wheel switch. The vent selection switch works well going up but is a
    little testy trying to go to the floor mode.
    My question is , could I lightly spray connecter cleaner in each switch or do you think I
    should just schedule a removal time and clean or change each switch? It's probably a dirty contact, and I would much rather not take it apart.
    What do you guys think?
    thank you Ed
  • You may not post replies
