Originally Posted by carnut The dimmer switch is located on the left side of the steering column and is adjustable. A rod passes down externally of the column and enters this switch. |
I've owned GM cars with this style of steering column almost all my life, and about half of them seem to have had the high beam switch misadjusted.
Try moving the tilt steering wheel all the way down to its lowest position, and see if the high beams will click on and off correctly. If not, try other positions of the steering wheel.
In about half of those cars I've had, I had to tilt the wheel all the way down in order to turn the high beams on or off.
If you find that's the case with your car, you can just tilt the wheel for the time being, but then someday or another you're going to want to get under the dash and adjust that switch. It's a little tight to get at, but once you're there, adjustment is easy.
