2002 seville not blowing air
Results 1 to 6 of 6
Electrical Technical Information Discussion, 2002 seville not blowing air in Item Specific Cadillac Discussion; Hey this is my very 1st post.thanks to u all im hopeful my blower will b running in no time. ...
    rickiricardo is offline Cadillac Owners Member
    Automobile(s): 02 seville sls
    Nov 2013
    4
    Hey this is my very 1st post.thanks to u all im hopeful my blower will b running in no time. So I just bought 02seville sls, drove it for a day and this morning after starting it up, I quickly raised the blower speedfrom 2 to the max of 5 notches on the center console, then quickly hit windshield defrost button and rear defroster at same time. The blower was picking up speed as I pressed the to defroster buttons and turned off after I pressed them.it has not turned on after that.so imtrying to figure out whats wrong. With a test light there is power up to the blower motor and the ground pin coming out grounds nice to the frame. The electrical connector going into the blower control processor and out into the blower have power. However both are not providing ground. My Q is where does this 3 pin connector ground itself on the vehicle? I smacked the blower wiggled connectors and checked fuses Its about 17 degrees outside. Check engine light is on , it says check gas cap on cluster and had minor front end damage, iassume thats the reason for air bag light to b on. Other than that yesterday when I drove it, iwas in love. Perfect everything its just gettin colder so I would appreciate any advice thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The ground for the blower motor is behind the passengers side kick panel trim. Open the passengers side door, and pull the trim straight up to remove it. If the clips stay in the rocker panel, just turn them 90 degrees, and they'll pull out.
    Nov 2013
    4
    Re: 2002 seville not blowing air
    Cool ill try when I wake up thanks4giving
    Nov 2013
    4
    This forum rocks moist cabbage is awesome. I found the ground with many other wires tested then all and one was messed up. Its fixed and I'm so grateful to have heat now. I'm sure I'll bon again soon. Thank u again qnd have a festive thanksgiving
    Sep 2010
    East Boston MA.
    29
    26,325
    Nov 2013
    4
    My driver seat when getting out goes back and makes a dragging seat noise that u can also feel. Might the sliders need grease or something? I don't have a manual. I can try oil?
  9. Remove Advertisements
