Left headlight dimmer then rught
Results 1 to 4 of 4
Electrical Technical Information Discussion, Left headlight dimmer then rught in Item Specific Cadillac Discussion; *****Sorry for the typo small keyboard****** I know, I know, change it. Well I did and one is still significantly ...
    Ninjobitch's Avatar
    Ninjobitch is offline Cadillac Owners Member
    Automobile(s): 1991 Sedan Deville 4.9l
    Aug 2013
    33
    81
    I know, I know, change it. Well I did and one is still significantly (half) dimmer then other only low beam. High beam are fine.bulbs are the same brand and strength what's going on.
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Can't tell your make model from the app, but check ground first. Some models use relays for each headlight IIRC, if yours does swap em see if it changes.
    Ninjobitch's Avatar
    Aug 2013
    33
    81
    Quote Originally Posted by rodnok01
    91 deville sedan
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Re: Left headlight dimmer then rught
    I would still start checking the grounds, relay(s) and the sockets/wiring for corrosion.
  7. Remove Advertisements
