Blinkers, gas gauge not working..
Results 1 to 5 of 5
Electrical Technical Information Discussion, Blinkers, gas gauge not working.. in Item Specific Cadillac Discussion; Ok, so a couple days ago, I changed my oil, and also installed a sound system, while installing the system, ...
    americanbodybuilding is offline Cadillac Owners Member
    Automobile(s): '95 STS
    Dec 2004
    Hamilton MT
    28
    91
    Ok, so a couple days ago, I changed my oil, and also installed a sound system, while installing the system, I accidentally, while tightening the positive battery terminal, caught the wrench on a grounded object, a few times... The last, resulting in the whole car turning off and not working for a damn a little while.
    Well now, when I put on the blinkers, the spotlight works, but the blinkers dont, and my gas gauge is constantly reading empty, with the whole "fuel level very low" thing going on. And one more thing, when i turn off the car, everything besides the headlights turn right off, they don't wait till you open a door like usual. Any help I could get would be awesome. I'm driving a 95 Cadillac STS.
    =Seth
    therodman is offline Cadillac Owners Fanatic
    Automobile(s): 1981 Eldorado 1994 Seville STS
    Mar 2005
    266
    Re: Blinkers, gas gauge not working..
    Does it blow the 10 amp ign fuse? I would check the tail light bulds, could have damaged a bulb or shorted the socket, ( weakest link ). If I'm not mistaken, the gas gauge and fuel message are on that 10 amp ign circuit.
    You grounded the wrench a FEW times, you didn't learn the first time! Your lucky you didn't really burn up your electrical system.
    Good luck...
    Dec 2004
    Hamilton MT
    28
    91
    No, no fuses are blown, all the head and taillight sockets are working, if someone has any idea, I could really use it, I've racked my brain and can't think what it could be, I even tried reprogramming my car's computer the way it says to in the manual, has anyone done this? Does a message come up or anything when you've done it?? Also, the compass is not working.
    =Seth
    Dec 2004
    Hamilton MT
    28
    91
    Ok, so Logan told me it was probably the fusable links, but I just noticed tonight that my front blinkers are constantly on, not blinking, but just on... if it was the fusable links this wouldnt happen, right?. I'm sure someone's ran across some kind of problem like this before, can I get some help here??
    =Seth
    Kowboyt21 is offline Cadillac Owners Member
    Automobile(s): 95 deville
    Dec 2011
    29
    1
    Was this problem ever solved? I recently purchased a 95 deville with the same problem.
    My DIC shows "fuel level very low" and my blinkers don't work. The previous owner says this has been going on for some time and every now and then both will start working together. I have not been able to duplicate this and I need a solution fast. No fuses or bulbs blown.
  8. Remove Advertisements
