A/C compressor doesnt engage at idle
Results 1 to 2 of 2
Electrical Technical Information Discussion, A/C compressor doesnt engage at idle in Item Specific Cadillac Discussion; Hello, I have a 00 eldorado and die some reason whenever in idling, the compressor doesn't kick on. Once I ...
    gway11 is offline Cadillac Owners Member
    Automobile(s): 1998 esc
    May 2012
    34
    13
    Hello,
    I have a 00 eldorado and die some reason whenever in idling, the compressor doesn't kick on. Once I tap the gas pedal, the clutch engages. Does anyone know where the problem is?
    My high side reading is a little lower than normal and my low side is a little higher than normal .
    rodnok01's Avatar
    Feb 2012
    NC
    6,634
    Re: A/C compressor doesnt engage at idle
    Sounds like a clutch problem more than a pressure problem. Are there any codes that might help?
