Results 1 to 4 of 4
Thread: Cycling parasitic drain 1989 DeVille
    Bones78 is offline Cadillac Owners Member
    Automobile(s): 89 Deville (Mary Kay?)
    Jan 2012
    38
    8
    After getting really sick of finding my battery drained I decided to check for a drain. I found one that cycles on every 15 sec or so and draws around 5 A. Pulled fuse for the radio and problem solved. Does anyone have any info on the RAP circuit? Is there a relay or module that needs replacing? If so where is it located?
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    34
    1,498
    Stock radio or upgrades
    Jan 2012
    38
    8
    Re: Cycling parasitic drain 1989 DeVille
    I wouldn't call it an upgrade, but it's not stock. I've read a few guys saying that decks are tough to install without causing problems. I've gotta rip that deck out anyhow, where should I look for problems? Just junk wiring jobs in general or is there a specific mistake that's often made?
    It's also worth noting that since posting, I'm still draining power from somewhere with the radio fuse pulled. I guess it's back to work with the multi-meter. Nothing like trying to identify 2 electrical gremlins.
  5. #4
    Apr 2007
    san diego
    34
    1,498
    Sounds like a loose ground .. How is the factory harness look. Have you checked your battery post. Are they clean and tiht is any other of your electronics acting up
  • You may not post replies
