Hey Guys,
just tried to replace the factory light bulbs in the rear doors - and apparently a short happened as i put in the LED bulb (rear touched both connectors)
Now the lights on the rear doors do not work anymore (hot wire rather cold) plus keyless entry stopped working altogether. No reaction on the 'LOCK' buttons inside the door panels as well. Trunk release only works from the button inside the glove box, front door lights still work, as does the trunk light.
I've checked the fuses below the steering wheel but all seem to be ok.
Any ideas what could be the problem?
