97 Caddy Codes - P0404 & P0603
Results 1 to 4 of 4
Electrical Technical Information Discussion, 97 Caddy Codes - P0404 & P0603 in Item Specific Cadillac Discussion; Here are the 2 codes from my '97caddy. I need some help explaining exactly what they mean. Thanks in Advance! ...
    tafari06 is offline Cadillac Owners Member
    Oct 2003
    3
    P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance
    P0603 - Control Module Long Term Memory Reset
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Re: 97 Caddy Codes - P0404 & P0603
    I have the P0603 one too... not sure what it means. Please let me know if you find out. Good luck!
    -Alex
    haymaker is offline Cadillac Owners Fanatic
    Sep 2004
    266
    Quote Originally Posted by tafari06
    My 97 SLS set the P0404 code when the EGR valve was sticking open. The consensus on the forum being remove and clean the EGR to correct the problem. I cleaned mine three times but the code would set each time I drove the car about five miles. I ended up replacing the EGR and that fixed the problem.
    I think the P0603 code is set when battery power is lost either by way of a loose or disconnected battery terminal.
    shorecc is offline Cadillac Owners Member
    Automobile(s): 1998 Deville D'Elegance
    Oct 2011
    Pt. Pleasant, NJ
    32
    18
    sorry wrong thread!
  7. Remove Advertisements
